1 - 1 of 1 Posts
I have the trouble codes p1574 and p0720 on my 02 maxima, auto transmisson. I have found that the p0720 is for the revolution sensor and is a pretty easy fix, however for the p1574 code I have found that it is the ASCD Vehicle Speed Sensor but I have not found out how to clear the code. Do these 2 codes go hand in hand? If I change the revolution sensor for the p0720 code will that take care of the p1574 or if not how do I get rid of that code? Also my cruise control DOES work.
Also I have found for the revolution sensor, if I get one from auto zone or somewhere it ranges between $130-150, however online I have found them as cheap as $12. Would it be safe to cheap out on this part or is this a part I should splurge on?
1 - 1 of 1 Posts
