1 - 6 of 6 Posts
which one is considered front? the one that the crank pulley is on, or the one that the flywheel is around in the bell housing? I need to order the one by the crank pulley, but i dont know which one its under if its the front or rear
Discussion Starter #2
NM, i looked up some stuff, and found that the one by the pulley is the front. Luckily advanced autoparts sells it for $5. mine is leaking bad as hell since i did the motor swap
How now brown cow?
Interesting, I didn't even take a chance with a store chain, I went straight to the dealer 'cause I was worried about getting the wrong part. I spent a dollar and some change more. Now if I could just install the pulley...
what chain? the crank seal is just a seal by the pulley. its easy as hell to change. took maybe 5 minutes
Breu Meister
he means, store chains...i.e. autozone, aid auto stores, uhhh other auto stores you guys have down south ya know. not an actual chain.
ohh, gotchya. the one I got at advanced worked pretty good so far. it was $5 less than the dealer, and im strapped for cash
1 - 6 of 6 Posts
