1 - 5 of 5 Posts
Hello everyone,
I have a 2003 2.5l , 170,000 miles
So my car had a knocking noise due to having a bad rod bearing, so I decided to replace the crank cause there was no way to fix the journal. I got everything apart, took out the old crankshaft and put a new one in. I also deleted the balance shaft. Then put the engine back together, I tried starting the car, something pope like a missfire, but it never started. I tried again, and again, engine is turning but don't want to start? ??????
I am suspecting that I have forgotten a ground wire laying around some where, does any one have a diagram for the ground wire??
Or can't even be anything else??????
It s weekend time , guess that you ll need to be a little patient mate .
I would try to get the ground diagram online .
Discussion Starter · #4 · (Edited)
Hahahaha, that's exactly my point, weekend! I got the manual for the engine ground wire, It seem ok on that. I am getting the codes p0225,p0125, p0335. Crank sensor, tps petal sensor and coolant sensor!!
The car was running before so I don't see why the crank sensor would go bad, unless if there is something else associated with that code
One more thing while I was replacing the axil to the transmission I broke a connector that is right on too of it. It seems like a coolant sensor but not sure if it would cause the car not to start
There is a video on YouTube called something like "Why your Altima won't start even with a jump" that tells about a problem with the battery cable and a set of fuses that are right there... I fixed my car doing this (starter motor turning, but engine not catching). I cleaned and tightened up the badly corroded battery cable while I waited for a new one to be delivered.
1 - 5 of 5 Posts
