1 - 19 of 19 Posts
Hey guys, first time posting, from down in New Zealand. I have a first generation Altima (called a Bluebird here and in Japan) sr20det 5spd 4wd. The clutch pedal has started to give a creaky sound when pressed, which a lot of grease on the springs did not fix. Is this a common problem? :( Any ideas on how to fix it or at least locate the problem?
got widebody?®
Mine does that too...haven't figured it out yet though, the car's going back in on Monday. At least you know you're not alone. :D
P.S. You are a bastard. (sr20det) :D:D:D
Gr8 to know I'm not alone. If you get the problem sorted, could you drop me a line with the solution if possible? [email protected]. Thanks dude. There is apparently a common fault with Pulsar GTIR's, whereby the pedal box breaks free from the bulkhead or something, I hope it is not this. Good luck.
Die Trying
mine needed a new rod and bearing. I had pretty much the entire clutch assembly upraded and replaced when i did my clutch and flywheel. I mean new everything exept clutch master cylinder, that is it, well, and bell housing, but you know what i mean
Mine started squeeking at 149,000 miles. Thought it was the pedal but didn't see anythihg that needed greasing and I wasn't gonna spray wd40 cuz it would suck to get that on the pedal side and get all slippery.
I hope I don't need a new clutch...
Jay
stick shifter.
yeah, mine does it too. The sound has been there for over four years now. We got the clutch replaced and it didn't solve the problem. I'm not too worried about it now, kinda used to it too. But if someone comes up with the right solution on fixing it, i'll get it done.
1 - 19 of 19 Posts
