Hey all, I've tried researching this and I'm getting conflicting information. Does anyone know the torque for the transmission pan bolts? And the main drain bolt?
CVT pan bolt torque settings 2021 rogue platinum 2.5
Hey guys, so I was able to find an online service manual. Within its a bit confusing and hard to navigate, it seems there are two different CVT's , and its hard to differentiate using this online manual. Anyway, I have a 2021 Platinum 2.5, and by looking at the shapes of the parts , and differences of size of the oil strainer, and the filter being in its own housing, opposed to being inside the oil cooler. Im attaching the relevant photos for my job. It looks like my CVT oil pan bolts are 70 inch / lbs , and the main drain bolt is 25 foot/ lbs. Also the filter housing bolts are 45 in/lb. The replacement oil strainer gets bolted 70 in/lb . Also including the bolt pattern for the pan. If I find anything different on the job, I will update. The online manual I found was at https://cardiagn.com/2023-nissan-rogue-t33-service-repair-manual-incl-wiring/ ( delete any popups )
PS Be careful of the diagram torque legend ( white wrench Vs Black wrench in.lbs - and ft lbs)
