1 - 7 of 7 Posts
I have a P0744 code. Torque converter clutch circuit intermittent. I have replaced the transmission fluid, still a problem. Any other solutions to fix this problem ?
Not really, the code comes with either clutch wear or internal trans wear unless you have a rare electrical problem with the circuit itself. You pretty much have to yank trans to fix it.
If you haven't wiped the code after the oil change you might want to, to see if it comes back up again.
Does anyone know the location of the TCC solenoid in the transmission? How difficult is it to remove? Does the transmission need to be removed?
Go there, register for free and service manuals at top of page header bar. Even the Nissan mechs don't get much info now, Nissan simply yanks entire trans as they do NOT want their own people even getting inside them, it doesn't make (steal) them as much money. So, the manuals do not go into very deep detail on CVT. You may find enough though.
1 - 7 of 7 Posts
