1 - 7 of 7 Posts
Hello all,
I am in gulf and I bought Nissan Sunny n17,
Its called Nissan Almera also and Engine is HR15DE,
Problem with car is that when car gets hot like driving for half hour then it loose power ... and RPM starts tickling when idle ... I feel gas smell also ... so sometimes I press accelerator rapidly to get more speed. Some people said it is fuel pump and some said injectors and some said ignition coil.
My mind say its ignition coil but I cant check them because they are under manifold.
I connected obd2 bluetooth adaptor to see some data at my android but because lack of knowledge I couldnt get any information ... ECU shows two addresses 7E8 and 7E9 ... 7E8 shows nothing no response but 7E9 shows only these => ECU name Transmission, RPM, Engine Coolant Temperature, volts, Throttle position relative and position B,
So how can I diagnose coils or fuel pump,
or how can I get readings from ecu for misfire.
Thanks,
Get a real OBDII scanner tool if you can't get your bluetooth dongle to work, or maybe just go see your Nissan dealer or even a garage with a scanner?
Coil packs are under the plastic engine cover...which is very easy to remove...but without a code, or a full set of spares, it's not going to do you much without understanding what the issue actually is.
Get your codes read and report back.
My engine is HR16DE which have coils under manifold ... bluetooth is reading 7E9 which gives me name of ECU written as Transmission, also RPM, Engine Coolant Temperature, volts, Throttle position relative and position B, nothing else. But it is not reading anything at all from 7E8.
So how can I read 7E8 or maybe by terminal I can issue some commands,
I will try to go for some garage to let them check codes.
And I can read codes from other engines easily except my sunny.
Discussion Starter · #4 ·
Today I got new symptom,
I drove too much today like 2 hours & when I stopped at signal ... everything was fine ... just fuel was down like two dots remaining ... at signal green I drove and as I pressed gas more engine went off totaly ... all dashboard lights were on ... first time I saw it going off like this ... I parked the car at side and restarted it ... it started back nicely but RPM was tickling while idle ... anyhow no error light/engine light ... what can be the cause of this?
Discussion Starter · #5 ·
another simptom ... when I turned on heater there is no hot air ... and recently I tried to keep my gas tank full ... no tickling in RPM but gas smell is there and loss of power is there
Discussion Starter · #6 ·
No error code for engine but
Following are the transmission error codes,
I have changed transmission oil yesterday as it was making too much problem and oil was burned black totally.
Now what with following too many codes.
My automatic Transmission Transaxle model number is RE4F03C
P062F Internal Control Module EEPROM Error
P0705 Park/Neutral Position Switch
P0706 Range Sensor A Line
P0731 A/T 1st Gear Fnctn
P0732 A/T 2nd Gear Fnctn
P0733 A/T 3rd Gear Fnctn
P0734 A/T 4th Gear Fnctn
P0744 A/T TCC Solenoid Valve Function
P0863 CONTROL UNIT (CAN)
P1701 Transmission Control Module (Power Supply)
P1735 First Gear Switch Circuit Malfunction
P1736 Second Gear Switch Circuit Malfunction
P1737 Lockup Solenoid System
P1738 Shift Time Error
P1744 Torque Converter Clutch System Performance
P17A1 Fault on the key locking control circuit (key lock) : Short circuit to earth
P17A2 Mechanical or hydraulic fault on reverse gear : Coherence
P17A3 Neutral detection fault (in mode R) : Not characterised
U0073 Control Module Communication with ECM/PCM
U0100 Lost Communication with ECM/PCM "A"
U0140 Lost Communication with BCM
U0155 Lost Communication with IPC Instrument Panel Cluster
U0300 Internal Control Module Software Incompatibility
U1000 CAN Communication Circuit
U1117 LOST COMMUNICATION (ABS)
Sounds like you have some money to spend now... I would seriously seek proper help...tranny oil should never get black, not in a healthy transmission anyways.
1 - 7 of 7 Posts
