1 - 8 of 8 Posts
I was plugging something in my power outlet in the middle arm rest compartment and it stopped working. I don’t know if it happened same time but my compass on my dimming rear view mirror doesn’t work either now. I checked all fuses and everything seems fine but those two things still don’t work. Anyone have any ideas as to what might be the problem?
Thank you.
Oh BTW I have Nissan Altima 2002 2.5 S
Well the way I checked it is that I took ALL of them out one by one and made sure they are all connected in the middle and not burned or broken. Thing is I was checking them one by one individually because for some reason power outlet or dimming mirror fuse isn’t listed in my fuse box or in the hood.
KUM4RSALTI
The power outlet is deffinatetly listed. There are two fuses, one for each outlet. I just changed both of mine. If I remember correctly one of them is on the left column right at the bottom and the other one is parralell to it. If you cant find I will go check later on this afternoon.
I take PayPal donations
This is for the fuse box inside the car:
Cig Lighter - 15A @ #7
Power Socket - 15A @ #5
Anti Dazzling Mirror - 10A @ #14
Thank you.
It is the 15a fuse for the cigarette lighter that burned out. Replace it and should fix the issue. It is most likely not the 10a fuse labelled mirror
1 - 8 of 8 Posts
