1 - 2 of 2 Posts
· Registered
Hi all,
Ever since I got my 2007 nissan altima 2.5s, the auto feature on the driver side window has not worked. The two stage switch works in the first position either way but as soon as I push it to the second stage the window just stops moving. When I pull it to the second stage then the window keeps moving but if I let go then it stops. The passenger side window works just fine both on the main panel and on the door switch. Should I replace the main window switch panel or do you guys think it could be something else?
Any help would be appreciated
1 - 2 of 2 Posts
