1 - 20 of 22 Posts
spinnin' !
I finally decided to paint my rusted looking calipers. So I went and purchased a Dupli-color kit. Here's a link to it: http://www.duplicolor.com/products/caliper.html . It was really simple to do and cheap. The kit came with almost everything you need. My rear calipers were particularly bad so I used a wire brush (not included)on them to aid in the removal of the surface rust. You also need either a tooth brush or what I used, a tile and grout brush, to help clean the surfaces with the supplied brake cleaner. There is plenty of paint in the kit for 2 coats on all 4 calipers. I only needed to do one coat since I chose the black color. It covered really well in a single coat. I'll see how durable it is and add a second coat later if required. My only complaint was the quality of the brush they included. It continuously lost bristles as I painted the calipers. My suggestion to people would be to get a little better brush. The final outcome looked pretty good considering how bad they looked to begin with. Gotta love Canadian winters.
I used this when I painted my calipers. I applied 3 coats. The first coat was a joke but the second and third coats were pivotal. It looks great. However, be careful what kind of wheel cleaners you use. I used a wheel cleaner and the paint started to run. I guess the chemicals in the cleaner were too harsh. Otherwise, I have had it on for over a month and it still looks great.
spinnin' !
Discussion Starter #9
I probably will do more coats this week sometime. The supplied brush I was using got really screwed after doing the 4 calipers with one coat so I kind of had no choice but to stop. Ran out of time and had no other brush. Still looks pretty good already.
Got VQ Power?? On Juice??
dsuave624 said:
Yup. Go to anyStrauss. It costs $20. They have a great selection of paints. Actually, RS Strauss has a great selection of everything!
Here is a location of their stores:
http://www.straussauto.com/sdaStoreLocater.shtml
dang people still shop at Strauss? i havent been there for ever now. i stoped going there cause the people that work there are stupid and dont know shyt.
That is true, but they have a better selection than both Pep Boys and Autozone. And the workers at pep boys and autozone are idiots too.
Murray's auto in the Chicago area has the Duplicolor caliper paint for $15.99 Red, Yellow, Black and Silver.
At least the one at Arlington Heights Rd and Golf rds does.
1 - 20 of 22 Posts
