1 - 8 of 8 Posts
i'm trying to reset the ecu because the check engine light in coming on again after installing nos. I looked for ecu in the service manual but only has ecm.. and i assume that the ecm is the same as ecu??
Discussion Starter · #2 ·
forget it.. it's impossible to reset it without one of those lil gadgets.
Destroyer of Sidewalls
You sure? Usually disconnecting the battery cables for 30-60 minutes will take care of it. Of course it can always detect the same error and reappear right away.
And yes, in my 96 Sentra/200SX service manual ECM=ECU
Discussion Starter · #4 ·
not with the 02 altima..
atleast 24hrs and that might not work..
u need to get it done with that programming thing
yes, you need to bring the car to the dealer to reset w/their odbii scanner.
Jay
G
You can get a code scanner but the problem as I found out is that Nissan is using new logic codes which only their consult II and newer GSTs use. Actron makes a scanner/dte code reader for around #375 which should work. The standard $200 code reader woun't read most of the new nissan codes but will erase the code from memory.
Unfortunately, clearing the memory by disconnecting the batter doesn't do the whole trick. By resetting the computer it will be able to relearn. One think you may want to do is drive two obd II driving cycle. I thought someplace in the service manual there was another way of using the car itself to clear and/or reset the default values.
Frozen Member
the dealership told me to turn the key to the 'on' position, let sit for 10 seconds, then turn off, then do the same thing again. he said that this resets it.
i've heard something similar with the ignition thingy before...
perhaps ask on the Nissan list. I'm sure someone technical there will know.
Jay
1 - 8 of 8 Posts
