ECU Pinout Diagrams
80014 Views 30 Replies 11 Participants Last post by  hmaznev
I plan on putting together a series of ECU pinout diagrams and attaching them to this common thread. If anyone has any they'd like to share, or finds an error, please post them over here. Thanks.
93-94 Altima ECU Pinout
http://www.stac-consulting.com/serrano.j/altima/ecu/93-94_Altima_ECU_Pinout.pdf (Rev. 0.2)
  • Like
Reactions: 1
21 - 31 of 31 Posts
Sure, I can get the '01 done as well. It's nearly the same as the '00 except for some minor differences. I should be able to get it done next week, if not, then keep bugging me.
Will do. When should I start bugging you? :D
'01 Altima ECU Pinout
Here is the 2001 Altima ECU pinouts,
http://www.stac-consulting.com/serrano.j/altima/ecu/01_Altima_ECU_Pinout.pdf
is it possible to find a 06 altima 2.5 ecu pinout pdf. Thank you
Expand my .sig, click on Altima FSMs, click on your year, click on EC.pdf. Search on wiring diagram.
Thank you so much that was very helpful
d0ugmac1 would you happen to have any info on taking a ecm plug harness apart,. someone has been in the harness before and pushed the pin connectors back inside of the harness plug i need to take apart and push them back into place so the make contact. I assume they didnt use a pin or a safety pin to check for a short and pushed the pc up inside the plug harness 06 altima 2.5l
thanks
I am afraid I don't...maybe post some pics and I can see if it is like anything else I've done though. Guiding principle is that it had to go together once...so how does it come apart again.
If the connector is a complete dog's breakfast...then maybe cut one out of a wreck and splice it into your harness?
Hello Everyone! Any chance to get the pinout of an Altima '02 2.5? Can't find it in any page, thank you so much
Do you have such a pinout diagrams for Micra 2005, petrol. 1.3 ???
21 - 31 of 31 Posts
