For anyone that is too cheap to buy the FSM, or too lazy to call your dealer to find out what the trouble code is, I took the liberty of posting all of them here.
This is straight out of the FSM
0908-Coolant Temperature
1103-A/T First Gear
1104-A/T Second Gear
1105-A/T Third Gear
1106-A/T Fourth Gear
0804-A/T Diagnostic Line
0401-Air Temperature Sensor
1208-ATF Temperature
0101-Camshaft Posistion Sensor
0307-Closed Loop
0103-Coolant Temperature Sensor
0802-Camshaft Posistion Sensor/Circuit
0608-Misfire Cylinder 1
0607-Misfire Cylinder 2
0606-Misfire Cylinder 3
0605-Misfire Cylinder 4
0701/Multi Cylinder Misfires
0301-ECU
0302/0514 EGR System
1005-EGRC Solenoid
1207-Engine Speed Signal
0704-EVAP System Pressure
0705/0213 EVAP Leak
0303/0409/0410/0411/0412 Front Oxygen Sensor
0901/ Front Oxygen Sensor Heater
0402/Fuel Temperature Sensor
0115/ Lean Air-Fuel Mixture
0114/ Rich Air-Fuel Mixture
0201/Ignition Signal
0304/Knock Sensor
0102/ Mass Air Flow Sensor
0505/No Failure
0208/Overheat
1003/1101 Park/Neutral Position Switch
0510/0511/0512/0707 Rear Oxygen Sensor
0902/Rear Oxygen Sensor Heater
1108/1201 Shift Solenoid
1204/TCC Solenoid
0702/ Three Way Catalyst System
1102/0104 Vehicle Speed Sensor
0215/0309/0903 Vent Control Valve
Hope this answers everyones trouble code questions
1103-A/T First Gear
1105-A/T Third Gear
0307-Closed Loop
0301-ECU
1005-EGRC Solenoid
0705/0213 EVAP Leak
0304/Knock Sensor
0505/No Failure
0208/Overheat
1204/TCC Solenoid
