1 - 6 of 6 Posts
I had the Eibach Prokit installed about 1 week ago
now the car is close to 2 inch lower in the front
Do I need to have the headlights adjusted cause their reflection range changed now??
Hispanic Causin Panic
i installed the sportlines and didnt have any problems with headlights needing adjustment. the car relatively was lowered all around in the back and the front so i dont see any need to adjust the headlights. i guess you can if you want to .
The Tat Man
I would adjust them up just a little bit. Prokits drop the front a little more than the back. I adjusted mine a little bit with my Sportlines even though it is close to an even drop. The headlight beams are not pointing straight forward (down a little bit) and with the drop I wanted to gain a little bit of the light distance back.
1 - 6 of 6 Posts
