Hey everybody,
I ran into a little problem. I installed a Ractive high flow intake (not a cold air), just the general one and now my engine light is on. There was this sensor that was connected inside the old filter box, but now it has no where to be housed. I don't know if thats the problem or not. All I did was disconnect and remove the stock filter box and replaced it with the Ractive filter/heat shield. I used the correct adapter and reconnected all the other stuff on as it was before except for that little sensor. The sensor just dangles right now and the engine runs fine. At first the RPMs were a little jumpy at idle but its all good now. You can seriously hear it pulling the air in. I didn't believe anybody who said it did, but it actually does and you can hear it even more at higher RPMS (obviously). It isn't like a frickin vacuum, but its enough to notice. Anyways, my engine light is on and I have no idea why (maybe just a coincendance). Any help would be greatly appreciated.
