1 - 3 of 3 Posts
Speaker of the Dead
OK the time has come. My 96 went into the shop this morning to replace the motor mounts and anti-knock sensor. I have an Apexi AFC, A/F Gauge, MSD pro-fire 6A ignition box, SS balster coil that I want to install next as well as a manual fan switch. I have the mounting posistions figured out but any wiring diagrams or advise would greatly help. Also, someone told me that I can run the A/F gauge straight to the ECU. Is this true? If so how? I thought I had to run the wires all the way out to the O2 sensor. Do I need to replace the plugs, cap and rotor to get the most out of the new equipment. What about replaceing the O2 sensor will that help as well? Thanx my brothas, PEACE
X-Mod
The O2 sensor wires at the ECU are the same ones at the sensor, so wire it there where it is protected from the environment. Use those alarm install taps that are removable too. O2 sensor either works or doesn't work. Don't fix it if it isn't broken.
1 - 3 of 3 Posts
