1 - 4 of 4 Posts
Well I've installed a Weapon-r intake on my 97 alty...anyways when ever i push the pedal to the metal my car seems to stall!!! and when it idles it seems rough at times. What could be the problem??
ASE certified wiseass
Hmmmm.
Did you beat up the temp sensor? Is you idle kinda high? How about the MAF sensor, you went easy on that right?
Maybe you have a loose harness somewhere.
What else does it do?
Randy
make sure you didn't lossen or crack any of the vacum or charcoal canister lines. I had a hairline crack on the back of a line the killed my idle and MPG.
1 - 4 of 4 Posts
