1 - 5 of 5 Posts
I'm looking for some information about the engine service soon (ESS) light. A month ago I was waiting at a stop light and the ESS lamp came on. The car seemed to be running fine. I called Nissan Service - they told me it was more than likely a sensor. I was told it was more than likely not a serious problem. The next day the light went out and did not come on until last week. At idle, I noticed the engine ran rough. I took it in to my mechanic. He ran the diagnostics and found a leak in the intake manifold, which he fixed. Ran great.
Two days later the light came on again. The car seems to run great - even at idle. So I decided to wait a few days to see if anything changes.
I saw on this forum something about reseting the control module. Any idea how to do that.
Also, I noticed the engine has 92 K miles on it. Could the light be a ploy to get me in for 90 K mile service.
VTEC wont save you....
Look in the FAQ forum for the ECU reset procedure.My SES came on about 1000 miles ago and I to it to Nissan and they stated the light was because I have no cat.(Even though my car ran w/o a light for 40000+ miles like that):rolleyes:The light went off a day later.
And no,the light comes on because something needs attention.It is not like other cars that give a service reminder.That was my 1st light after 104K.
Oh,and the FAQ also shows how to get the code for troubleshooting before you reset it.:)
Premium Member
Without a code scanner, you can still get the computer to send back the fault codes to the engine check light. It typically requires jumping two terminals on a harness connector. The procedure varies with the car in question. Let me know if you need it for an Altima and I'll post the procedure straight from the service manual.
Premium Member
1 - 5 of 5 Posts
