they are urethane right? or fiberglass>?thanks.
could you please enlgihten me to how there stuff is cheap copied shit?ALtiMa-SeR said:i always thought erubuni is fiberglass cause all there stuff is cheap copied shit
Newsflash, we are in A-M-E-R-I-C-A. we're lucky they even make kits for the altimas. Urethane is Urethane.ALtiMa-SeR said:erubeni copies kits made in japan ... erubueni is just cheap... and im pretty sure its fiberglass. if u go to japan ... ull see the real kits and erubeni just makes fake ones .. they're just cheap knockoffs like tenzo r and all those others
DJ Prophecy said:hey i liek my full erebuni 905 kit. and the front and rear are urethane and the sides are fiberglass!
ALtiMa-SeR said:this is from kaminari website: We use high pressure BASF Urethane which is OEM grade material. Our urethane components will retain it¹s shape in all weather conditions. The machine we use to inject the urethane is up 10 times more expensive than our competitor¹s. Most competitor¹s machines couldn¹t even process the urethane that we use.
and if u look under the erubeni website.. the 257 kit is fiberglass and the 905 is urethane....
All Kaminari components are meticulously constructed from hand-laid fiberglass or urethane and are guaranteed to fit right every time.
Q. Is all Polyurethane components the same?
A. No. We use high pressure BASF Urethane which is OEM grade material. Our urethane components will retain it¹s shape in all weather conditions. The machine we use to inject the urethane is up 10 times more expensive than our competitor¹s. Most competitor¹s machines couldn¹t even process the urethane that we use.
Me Too. He must got his from JapanRolnAlty said:
hmmm seems to me that i have the erebuni 905 sides and rear and there urethane i don't where u got your erebuni kit but mines all urethane
