1 - 4 of 4 Posts
Jr. Lord Of Search
my exhaust is making a rattling or scraping sound or something like that at high rpms, could it be my motor is twisting so bad (bad mounts?) that it is causing the muffler to scrape?
Negative
Check all of the flanges for signs of rusting (exhaust leak), or two pipes possibly "slapping" against each other if the bolts are rusted out.
Pos Performance Pres.
yo i had the same problem it turned out to be a loose heat sheild so check all along your exhaust pipe expecially near the cat and have some one rev the engine and try to pick out which sheild is rattleing
1 - 4 of 4 Posts
