This is to stop all the questions since the site seems to be growing more and more and the question is frequently asked:
How do I put 6x9's in my first gen.
6x9's were factory on 93 and 94 GLE trim level Altimas with the factory Bose system.
All first gen altimas have the mounting holes for them.
The GLE has a different back deck, and 2 plastic trim pieces that fit over the factory 6.5 holes on which the 6x9's are bolted to.
If you want 6x9's you need to find a junk GLE, or go to the Nissan dealer and go to the parts department to see if you can get them.
Installation is the same as regular 6.5's
Remove the 2 bolts holding the bottom seat cushion in.
lift the flap connecting to the arm rest there are 2 bolts under it along with 2 bolt holding the back seat cushion on.
remove the seat back
the rear deck pops off, you can either push the plastic tabs from underneath or just pull from the top.
Then just unbolt/unscrew the speakers and add the trim ring and 6x9's.
Any questions just reply to this sticky as I will check it periodically.
Until this thread becomes part of FAQ
Thanks
stealthmode20
Thanks
stealthmode20
