Thanks for the reply
I checked the polarity and the fobs work, doors unlock, panic button works. Just every time I start the car the low fob battery light comes on. It is only with the one fob, the other doesn't give the warning.
This is an OLD thread and key FOBs have changed so much from 2010 to 2021. However I happened upon this post after seeing that low battery warning after a new battery was put in. Today, what works is to tap the brake and use the key to push the start button. It'll program itself and in a perfect world, the warning msg should be gone. I hope this helps someone.I replaced the battery in my fob last week and I am still getting the low battery light on the dash. I checked the other fob and that one is good, no warning. I replaced the battery again with a brand new one and the warning is still on the dash. Anyone else had this before? I bought the batteries new, one was an AC delco brand the other was an Energizer. Is there any thing you have to reset?
Thanks,
Just unplug the battery terminal for 1min and reconnect then it should workyou are so right ! common sense.
That was scary....lolScar(r)y indeed.............
