1 - 4 of 4 Posts
Hello I am new to the forum! I recently purchased fog lights for my pre wired 2009 Altima 3.5SE. I was wondering if it was possible to not buy the OEM fog light stalk and install an inexpensive button using the provided wiring from Nissan.
2010 2.5 SL
You can certainly use an aftermarket button, but I do not know if you can just hack into the provided wiring to make it work. I'd just bypass it and use the wiring that I assume came with your kit.
What specifically are you trying to do? I installed fogs a few different ways on my 2010 and might be able to give some help/insight.
Thanks for replying. I know how to set up and install the fog lights I can also do all the wiring if needed. I just wanted to know if I can use the provided wiring that was pre-installed by Nissan to set up a button without buying the expensive stalk or using the aftermarket wiring from the kit.
2010 2.5 SL
Sorry, I never had any reason to try. I'm too much of a pessimist to risk splicing a line into the ECU without knowing for certain that I wouldn't fry the whole thing.
But, I am a touch confused by "expensive stalk". You can get the stalk AND oem lights for $90 from Courtesy.
1 - 4 of 4 Posts
