I was wondering, what are the side effects if the tape comes off? - - If the tape came off, it might fall out the front hole, or suck up onto the filter that you have. It wouldn't suck up into your intake though. I'm sure the power difference from taping and not taping might be less than 1HP, since modifying the intake breather in any way usually results in 5-8 HP increase for the most expensive intake.
Also, is there an alternative to taping the hole? - The alternative would be to remove the resonator in the fender well or just leave it untaped, but you are now having some of your air go down into that chamber and not all of it going into your intake manifold.
How big of a difference is there when using the stock air filter and replacing it with another one? - Once again, probably 2-3 HP if you are to use a drop in K&N filter that is the same size as the factory filter. Also, this type of filter does not void the warranty. You are just using a servicable filter rather than a throw away filter.
And finally, I'm assuming you can only pick between doing this and adding a CAI, is that assumption correct, or can you have both? - If you are getting any warm air (or engine compartment air) into your intake manifold, then you are not running a COLD air set up. So, if you were to run a pipe down into your fender well and also have it "T" and have another pipe open in your engine compartment, you I guess have a set up that is like both, but you are really still getting warm air. (WAI) So... If you want a CAI (cold air setup) you must isolate your air box opening to only taking in air that is coming from outside the engine compartment. There are lots of threads on this.
