are the front and rear shocks and struts the same ? I can’t seem to order the right ones
The front suspension is a combination shock/strut assembly while the rear is shocks only. The two are entirely different. If you go to 2006 NISSAN ALTIMA 2.5L L4 Strut / Coil Spring / Mount Assembly | RockAuto you'll see the difference.are the front and rear shocks and struts the same ? I can’t seem to order the right ones
