1 - 1 of 1 Posts
I noticed this problem started coming around gradually after I installed air suspension. It is consistant but does occasionally go away from a bump, or something. It does seem to squeak proportionally to the rotation of the tire. It will go away if I press on the brakes but will come back as soon as I release it.
i can’t usually tell if it occurs at higher speeds because of road/car noise but occasionally I’ll hear it.theres been no noticeable reduction in braking, steering, acceleration.
i believe it’s a wheel bearing, pin in the brake caliper, suspension bushing, or sway bar bushing
1 - 1 of 1 Posts
