1 - 16 of 16 Posts
· Automotive Lighting Experts
240SX LED Turn Signals
Switchbacks will require basic socket and wiring modification. Please call: (314) 205-3033 for more information
Click to order or for more information:
240SX Turn Signal LEDs Front Turn Signal LEDs
240SX Turn Signal LEDs Rear Turn Signal LEDs
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
SMD60: 30 amber and 30 white 1210-size Epistar SMDs arranged in 360 degrees. Eight radial panels of six chips, and a forward-facing twelve-chip panel.
HP60: 60 dual color 2826-size Epistar SMDs arranged in 360 degrees. Six radial panels of eight chips, and a forward-facing twelve-chip panel.
Included in your order is TWO BULBS.
SMD27 Amber:
HP11 Amber:
XP80 Amber:
Switchbacks with Turn Signal Activated:
How to Install Resistors for LED Turn Signals, Fix Hyperblinking! - YouTube
Hyperblink Fix: The turn signals on most vehicles will begin to blink fast (hyperblink) when LED bulbs are installed. This is because LEDs use less power than the original bulbs, so your vehicle thinks that the bulb is out. There are two ways to fix this:
Resistor Kit: This is a universal way to fix the issue, and will work for any vehicle. By adding a resistor to the bulb's circuit, you can mimic the power consumption of the original bulb, and return the vehicle to normal turn signal speed. The installation takes 10-15 minutes, and involves making two simple connections. Everything you need is included in the kit. If you have both front and rear LED turn signals, you usually only need one set of resistors, on the front or rear, to create enough resistance for the turn signal circuit.
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty. For more information, please view the FAQ guide.
If you have any questions, please don't hesitate to post, PM, email
[email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
***MORE PICTURES COMING***
Thanks for looking!
Nick C.
Diode Dynamics
Discussion Starter · #2 ·
Our Memorial Day sale starts NOW! Today through Friday, 5/29/2020, save 20% on all LED upgrades, including our LED Turn Signal Bulbs by entering coupon code "USA20" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 5/29/2020. Cannot be combined with other coupon codes.
Our July 4th sale starts NOW! Today through Monday, 7/6/20, save 15% on all LED upgrades, including our LED Turn Signal Bulbs by entering coupon code "JULY4" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday, 7/6/20. Cannot be combined with other coupon codes.
Discussion Starter · #4 ·
Our Labor Day sale starts NOW! Today through Tuesday, 9/8/2020, save 15% on all LED upgrades, including our LED Turn Signal Bulbs by entering coupon code "LABOR" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday, 9/8/2020. Cannot be combined with other coupon codes.
Discussion Starter · #6 ·
This is NOT a drill! Our Black Friday sale starts NOW! Today through Monday, 11/30/2020, you can use coupon code "BF15" at checkout to save 15% on all LED upgrades, including our Turn Signal Bulbs.
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday, 11/30/2020. Cannot be combined with other coupon codes.
Discussion Starter · #7 ·
Don't miss out on our lowest prices of the season! Through Monday, 11/30/2020, get 15% off all our LED upgrades for your ride, including our Turn Signal Bulbs.
Use code BF15
Collin
Diode Dynamics
Discussion Starter · #9 ·
Our Memorial Day sale starts NOW! Today through Friday, 6/4/2021, save 15% on all LED upgrades, including our LED Turn Signal Bulbs by entering coupon code "USA15" at checkout!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 6/4/2021. Cannot be combined with other coupon codes.
Discussion Starter · #10 ·
Our July 4th sale starts NOW! Today through Thursday, 7/8/2021, save 15% on all LED upgrades, including our LED Turn Signal Bulbs by entering coupon code "JULY4" at checkout!
Plus, all orders over $300 will receive a free Diode hat!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Thursday, 7/8/2021. Cannot be combined with other coupon codes.
Discussion Starter · #11 ·
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 7/8/2021, you can use coupon code "JULY4" at checkout for 15% off your entire order of lighting upgrades, including our LED Turn Signal Bulbs!!! Don't wait, this sale ends TONIGHT!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Thursday, 7/8/2021. Cannot be combined with other coupon codes.​
Discussion Starter · #12 ·
Now's the time to upgrade your ride! Our Labor Day Sale is going on NOW! Save 15% sitewide, including our Turn Signal LEDs, by entering coupon code "LABOR" at checkout! And, all orders over $300 will receive a free Diode flag tee! Sale ends Friday, 9/10/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/10/2021.
Sale excludes preorders.
Discussion Starter · #14 ·
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our Turn Signal LEDs, with coupon code "LABOR" at checkout! Plus, get a free Diode flag tee when you spend $300! HURRY, this sale ends TONIGHT!
John C.
Diode Dynamics
Discussion Starter · #15 ·
Now's the time to upgrade your ride! Our Black Friday Sale is going on NOW! Save 15% sitewide, including our Turn Signal LEDs, by entering coupon code "BF21" at checkout! And, all orders over $500 will receive a free Diode Dynamics long sleeve shirt! Sale ends Tuesday, 11/30/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday 11/30/2021.
Discussion Starter · #16 ·
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our Turn Signal LEDs, with coupon code "BF21" at checkout! Plus, get a free Diode Stage Series long sleeve shirt when you spend $500! HURRY, this sale ends TONIGHT!
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST | Tuesday, 11/30/2021.
1 - 16 of 16 Posts
