1 - 1 of 1 Posts
Kicker KX1200.1 AMP
This a slightly used, (less than 10 hours), Kicker 1200.1. This amp is in excellent condition. · Class D design · frequency response 20-200 Hz · 300 watts RMS x 1 at 4 ohms 600 peak · 600 watts RMS x 1 at 2 ohms 1200 peak · 1200 watts RMS x 1 at 1 ohm 2400 peak · Signal to Noise Ratio: 95dB · Input Voltage: 13.8V · THD: 1.5% · stable at 1 ohm · MOSFET power supply · variable low-pass crossover 50-200 Hz at 12 dB per octave · KickBass provides up to 18 dB of boost at 40 Hz · switchable subsonic filter 25 Hz, 12 dB/octave improves efficiency by eliminating low frequencies below the range of human hearing · preamp- and speaker-level inputs · preamp outputs · remote bass level control · Amp-Strapping circuit allows two KX1200.1 amps to be joined to produce double power (must be connected to a 2-ohm load) · fan-cooled · dimensions: 22-11/16"W x 2-5/8"H x 10-1/4"D.
All original parts are all included. (amp, amp cover, fuse box, fuse, remote, ect..)
$325 Shipped and I am including $500 shipping insurance !
The best way to contact me is on AOL AIM: John00GTP
1 - 1 of 1 Posts
