21 - 22 of 22 Posts
So two different clusters behave the same way...right down to whacking the dash to get the reading to work? Sounds like a wire or some corrosion on the connector pins. Try running a new wire straight from FP sensor to the cluster (leave existing wiring in place, just press bare end of sensor wire to solder point connected to the pin for the same signal (ie put your new wire in parallel with the old wire, but bypass the connector and follow the trace to the next exposed circuit point)
21 - 22 of 22 Posts
