1 - 6 of 6 Posts
i run blogs.
yea when im driving there is a loud grinding noise sounds like its coming from the front wheels. when i hit the brakes, it goes away. my brakes shouldnt need replacement, they were replaced like 6 months ago. what the hell is this? do i new brake shoes?
Shadetree Mechanic
Check the backing plates behind the rotor. I had this problem. Other than that maybe you got a sticky caliper? I'd check it out before you junk ur rotors.:D Good luck!
Shadetree Mechanic
you can get cheap decent pads for like 50$(Can). Have someone check em out for you before you buy em.
Formerly LordofSearchMod
why not take it to the shop you got it done at.. if its anyplace where they have the warranty, they should fix it.. sounds like either something is caught or missing.
1 - 6 of 6 Posts
