1 - 5 of 5 Posts
Wanted
Just wanted extra confirmation that GC's and Tokicos will work together, as mentioned before?
http://www.altimas.net/forum/showthread.php?s=&threadid=30379&highlight=tokicos+and+ground+controls
http://www.altimas.net/forum/showthread.php?s=&threadid=40244&highlight=tokicos+and+ground+controls
http://www.altimas.net/forum/showthread.php?s=&threadid=52759&highlight=tokicos+and+ground+controls
For others that have them now, how do you like them? What do you do to replace the cap/hat that couldn't fit?
clean freak
you don't replace the cap, the GC sleeve slides over the strut assembly once the cap is removed and that is it. Keep the caps though in case you ever have a problem.
Wanted
Thanks. There shouldn't be any problems with the caps off, right? Like dirt and foreign debris getting in and dramatically shortening the life of the strut or affecting its performance?
clean freak
Either reinstall the strut boots or buy new ones from tirerack.com ($10 each). They will keep most of the dirt and grime out. It shouldn't be a problem. They zip tie to the strut assembly which would cover where the caps go. Not sure if the fit inside the springs of GC's though. you might have to cut them a little.
1 - 5 of 5 Posts
