1 - 8 of 8 Posts
no ordinary sedan
For the past 3 days my car has not started. I turn the key in the ignition and it chugs and chugs but will not turn over. I keep the car outside so cold wind hits it all the time. Do you think the fuel line has frozen? It has a little under a half of a tank of gas and I put fuel antifreeze stuff in the other day to try to let it soak in. Its done this before... once in the car wash (I know... ugh) and another time on a fairy decent day (it was around 30 degrees and sunny). Last time we pushed it into the garage and it started after an hour or so of being in there. Any ideas whats wrong????:angry4:
Battery is getting weak or actually the starter is and because it's weak it's taking more power to turn itself over, thus draining your battery down. That would be my guess...but hey, it could be a lot of things, even your fuel pump.
Cheetah
Let me guess - the other time, it either rains or snows the day before and you parked your car outside, right?
If your answer is yes, I know the answer and have the solution. :D :D
uhm maybe check your battery or your fuel filter or maybe your ignition?
1 - 8 of 8 Posts
