1 - 16 of 16 Posts
older then dirt
update on headliner rattle
HELP.....
does anybody know the end results with
solutions from dealerships on the rattles in the headliner/sunroof ??? for those of you who
had them....thanks!
JIM :(
do you have a sunroof?
if not - then it's most likely the dome light rattle - search around
if you do - mine is getting fixed for it tonight - part a little out of spec behind the headliner - should have it back by 5 pm. They sent a Nissan Corp. Tech out to check it out as well.
older then dirt
yes, mine has a sunroof, what was out of spec? are they replacing the entire headliner? or just a part?...thanks!!
JIM:(
they replaced the headline causer they thought one of the wires that were internal - for the light - was making that noise - and they said it was delaminating. That solved the problem for a few days - then it came back.
Then I brought it back - but since it was raining - they couldn't hear it - so I when I heard it again - I drove there - got the Tech and made him ride with me. He heard it - said to bring it back today - so I did. Now they have that same tech - and a corp. tech - working on it now - they did say they found it.
I'll know more when I pick it up tonight - so I can read the work order and talk to the Tech.
older then dirt
Discussion Starter · #5 ·
thanks,..... let me know how it all works out....
I appreciate your help....JIM
ok - the headliner has been fixed.
There is a brace - between the headliner and the roof of the car - under a load this brace would flex a little - causing the rattle. This brace is a little on the thin side - which is why it flexed - and caused the noise. They reinforced the brace and put in extra insulation in the roof. They are washing it now, and it'll be ready for pickup tonight!
older then dirt
Discussion Starter · #9 ·
Yeah....... all the joys of being the first kid on the block
with a new toy!!!!......guess somethings got to give....
Good luck,......thanks for the feed back.....JIM
ok - the lady on the phone described the problem completely wrong. I talked to the tech and this is what it is.
There is a cross beam for support - for the sunroof and headliner - behind the sunroof. This was rattling against the roof. It was fixed by padding the entire crossbeam between it and the roof. The problem is indeed fixed.
I am 100% positive that it was not the sunglasses - because I don't keep my sun glasses in the car - nor do I keep anything up there. But that was where I first looked. If you open the sunroof sun shade - you can get an ear up ther and listen - it was coming from above the passenger seat. That was confirmed with a steth-o-scope.
Also - the dealer took down the headliner - and then drove around and still heard it - before fixing the cross bar.
I've developed the same rattle in my dome light. I'm 43 miles from my dealer so I'm not looking forward to takeing this in. I wish I could make the repair myself.
I had the same problem.. And that is exactally what it was.. They just added extra support and now it is fine.. :) they fixed this like 3 months ago on my car as well and i have not had this problem since. BUT it is still happening in my steering column ERRRR...
I can't believe everybody's dome light rattles, thats funny cause mine rattles to. I just ignore it. Seems like every time I take something back to the dealership, it either comes back worse or they wreck something else and piss me off worse! I think dealers suck!!
1 - 16 of 16 Posts
