I't a good idea to put it back on because it helps pull the engine heat under the car when driving, instead of rissing up, creating higher under hood heat. To get the broken bolts out go to a tool supplier and ask for a "easy out" , that will remove the broken bolts. Then use a tap to clean the hole out.
