1 - 2 of 2 Posts
I have a 2015 altima 2.5 and a few days ago it started blowing cold air to the feet on the drive and passenger sides no matter which settings the vents are on and what speed the fan is on. The only way there is warm air is if I set it to feet with the heat on full and turn on the recirculate button. All of the other vents work fine.
What does the engine temperature gauge needle show? If it's below its normal position you could have a stuck open thermostat.
Check the condition of your engine coolant. If it's rust colored, you might have a clogged heater core which would be a big hassle to get at.
1 - 2 of 2 Posts
