1 - 8 of 8 Posts
i just put on my 2" drop zone springs and i was just wondering if its normal for the back tires to be almost level with the wheel well and the front tires to have a 1" - 1.25" gap. cant really tell from far that its off but from close i have been questioned by my frieds if that was suppose to be how it is. just wonderin.
layin rubber on philly
damn, didnt know that. buy if you drop the front more then will the tire scrape the side.
what side and why?
Jae
mrdeucie said:
I think he means will it scratch the fender because the car is dropped low enough that it won't clear the fender.
oh. When I put on 215 wide tires, I was scraping the plastic closest to the engine when turning full lock. I just adjusted the bolt that limits your lock turn radius.
Jae
de-moderator
you wont have to worry less you go REALLY REALLY LOW. I am runnin stock tires and DZ's cut upfront and back. the rear is cut 1 coil off and front is 1.5 coils off. I'd say its around 4inch drop. Here's a pic. I have around 1/2 inch wheel gap upfront and no rubbing at all. I say chop 1 coil off if you dont want a really extreme drop. But, cuttin the springs DOES make the ride quality worse.
1 - 8 of 8 Posts
