1 - 8 of 8 Posts
i just put on my adapter intake today and there is a problem. when i hit the gas, the engine first bogs down a bit and then accelerates pretty much normal. Is it running too rich or what? anyone else have this problem?
thanks
Alcoholic
try resseting the ecu.. go to FAQ's page.. if that doesnt work.. u're adapter/intake sucks dick!!!!! what kind is it?? u get what u pay for!!!.. u prolly have a leak or something.. reset ure ecu first
Joshy said:
its a 1993 GLE and there is no leak, the intake is just some no name adapter one
did you put it on right? Have you tried to reset you ECU yet..that might be the best idea like n20 altima said
Official Troll
Also, did you put back the air temp sensor?
Discussion Starter #7
i didn't have to mess with any sensors, it bolted on right where the airbox did before, i'll reset it in the morning
uh...that's what intakes generally do...u don't have a problem as long as your vacuum's good. Reset the ecu if you're paranoid, but you're ok.
Jay
1 - 8 of 8 Posts
