1 - 4 of 4 Posts
The bottom left fuse in my 94 altima blows all the time. The fuse controls power windows, transmission and a/c along with the abs. The abs is what is causing the fuse to blow. I would like to disable the abs while using the other features on this fuse to confirm this.
How can i disable the abs other than pulling the fuse
I dont think this is the best solution for your problem, its probably something grounding out, but I pulled the computer near the dead pedal, pull of the kick panel cover, and pull the carpet up, right where you rest your left foot.
1 - 4 of 4 Posts
