1 - 4 of 4 Posts
X Factor
I just got my car back today from having an engine swap. The mechanics won't be back until Monday. Here's the problem: Whenever I push the accelerator in all the way the engine keeps accelerating when I let off. The pedal seems to return to almost the normal position and pulling out on the pedal does not help. I had to put the car into N and back into D while on the highway to correct the problem! I know it's probably in the TB but would like your suggestions on what to do! I NEED MY CAR!
Thanks
"Realistic Dreams"
I had the same problem , my car would just keep revving and revving . It was the throttle cable , It was shreaded near the firewall causing it not to ratract . Check that first , cheap to replace .
1 - 4 of 4 Posts
