Its just the drivers side? Its probably wiring. If the switch was bad none of them would work.
Um...no...if one switch in the master panel goes bad, it will not affect the operation of all the switches. However if lets say the passenger front window switch on the master switch goes bad, the passenger front window switch on the passenger door most likely will not work.sonicxtacy02 said:The drivers switch is a master... meaning if it fails none of the windows will operate.
HOW CAN I FIX THIS ISSUE? My driver’s window won’t go up or down, but the other windows are working fineUm...no...if one switch in the master panel goes bad, it will not affect the operation of all the switches. However if lets say the passenger front window switch on the master switch goes bad, the passenger front window switch on the passenger door most likely will not work.
