1 - 8 of 8 Posts
Please help I'm a fully bolted 6spd manual 2005 SE-R. I have and Apexi neo and 4" intake with AEM uego wideband I need to install. I'm I desperate need of the ECU pinout for my car. Velicos posted one awhile back but the pictures no longer load. Thanks in advance for your help.
For those curious my mod list is:
SFR manifold, OBX headers with modded Y-pipe (3") into straight 3" piping, magnaflow race series !muffler s, NWP BB TB kit, NWP 5pcs spacer kit, Apexi Neo, AEM Uego Wideband, and 4" intake
My little champion...
I may be incorrect, but if I recall, doesn't the SE-R share the same connector and pin out as the 03-04 350Z?
Yes the ecu is the same and pinout is very similar. I was able to get the wideband, Apexi neo, and 4" intake all installed. By far the best bolt on upgrade for our cars
Thanks - I like these as a daily.
I still got some 19" Rays G-Games Wolf 77 rims sitting in the garage with new tires, but haven't rode on them for years. Guess I will put them on the next vehicle if they fit.
Yo KeVQ35 I'm digging those 07-08 maxi wheels in that pics.. Looks nice with your drop!
4DR-350Z
Neo Wiring
05-06 V6 ECU Pin Wiring
Verify this is the view from the wire side.
Count Twice Verify With Digital Multi meter
Settings
Hot Wire Arrow Pointing Up
Set Engine(RPM/Tach) Type - 1 Cylinder
Discussion Starter · #7 ·
Neo Wiring
Settings
26 in/ 26 out
Low throttle 49%/ high throttle 50%
If your running a 4" intake set all your RPM points starting 750,1000,1250,1500,1750,2000,2500,3000,3500,4000,4500,5000,5500,6000,6500,700
And start out with everything on +30 on the high and low maps. This will get you running good enough until you can perfect your tune. From 750rpm to 3000 rpm your target A/F is 15.1 and after 3000 rpm the target A/F ratio is 13.1-13.3. This will account for the timing bump the VQ35 has.
Thanks for posting that up Everett
1 - 8 of 8 Posts
