I have the Turanza H tires (automatic transmission). There is no sticker in the door nor on the underside of the center arm rest. I did a search on tire pressures here on the forum and found 33 front and 30 rear as what was recommended. I went an adjusted them to that pressure, they were at 40 front, 35 rear.
With more careful reading of that thread that stated the pressure numbers I saw that it was the pressure for the V rated tires with the manual transmission. What is the recommended or best pressure for the H rated tires.
