1 - 4 of 4 Posts
the trailer's rockin
that's actually 2 codes. 0103 and 0908. both of them deal with the coolantsesor if i'm not mistaken. i'll see if i can find my haynes to double check that for ya.
Odirt, were you able to verify thise codes? Is there some where online I can check these codes?
Thanks
according to my haynes manual, 0103 is coolant temp sensor, "the coolant sensor or circuit may be shorted or open. check the coolant temp sensor and circuit." 0908 is also coolant temp circuit, "check the ect sensor and circuit."
i would suggest you spend the 15-20 bucks on a haynes manual. not only will it give you the codes, it goes into some detail on solving most problems.
edit: here's a thread from page 3 of the faq that gives you trouble codes. make sure you look t the column titled ecm1. the codes are p**** are only useful if you use a scan tool to get the code
1 - 4 of 4 Posts
