1 - 3 of 3 Posts
so i am installing the bee-r rev limiter 2 step unit into my 2008 Nissan Altima coupe.
not sure where to wire in the yellow,green,red,black and white wires in to the ecu, also with the fact that the grey brown black ecu connectors witch one do I connect into
ant help would do swell thanks
101953
  • Cuts ignition on hitting a rev limit
  • Fuel cut is not used, therefore flames can appear as fuel is dumped out of the exhaust
  • Ignition cut is preferred over fuel cut. Fuel cut, as used on many standard vehicles, risks damage to high performance engines when at high revs.
  • Ignition cut is used in F1, WRC and other forms of motorsport
  • Should only be installed by an experienced mechanic
  • Makes you the envy of ricers everywhere as flames shoot out your 13 year old car's modified exhaust
  • Upsets more neighborhood dogs than fleet of UPS trucks
1 - 3 of 3 Posts
