1 - 3 of 3 Posts
the trailer's rockin
aight, i bought a couple 10s and an amp, used from a buddy of mine, installed w/ no probs. then, my wife hit a bump in the road, and one of the 10s slid across the trunk, ripping the wire outta the terminal. i fixed that, tested it, no probs. then i decided to use small "L" brackets to hold the sub boxes to the plywood i used to mount the amp on. i did that, then i hooked my amp back up, and it's gettin power from battery, and remote turn on, but it doesn't come on. any ideas?? btw, the fuse in the rear of the amp is good, so is the inline fuse at the battery.
Discussion Starter #2
aight, thanx for the 8 views w/ no replies. i found that my amp ground was loose.
mods, u can just delete this, or leave for search purposes, i don't really care.
1 - 3 of 3 Posts
