1 - 2 of 2 Posts
jdm
where do i hook the two black vaccum hoses that come off of the zex brain... one is supposed to go to the fpr and the other to an unused line on the intake... can someone explain in more detail or take pics of where they go.. im lost.. thanx in advance.. -Scott
EXPLICIT EDITION
The one that says fuel you can hook it up the the hard line that comes across the top. If you can't find it just follow from the FPR the fuel line that goes to the hard line. It's easier that way so you won't have to have the line going all the way to the FPR. So what your looking for is the rubber line that goes to the hard line. I just hooked up the fuel line to the hard line cuz it was closer and it works just fine. The vaccum line just goes to one of the intake tube lines. And if you can't find the TPS switch, it's the one right by the throttle body. I'm pretty sure it's the white wire that you have to splice into. I'll check my car later to see which one it was. Good luck.
1 - 2 of 2 Posts
