1 - 9 of 9 Posts
Grrr >_<
Ok i have a issue with my check engine sign. It came on today while driving on the highway at 55 mph on cruise control after like 4 to 5 miles of driving. Has anyone had this problem? If so did you find out what was the cause? thank you in advance Oh yea and the sign went off when i hit the gas pedal and increased the RPM.
neil
Pacman
Sometimes it is hard to get a good code reading when the light is intermittent. TPS or something maybe.
Resident NICO Mod
a code is stored even if the light goes off. set the ecm to diagnostic mode and read the flashes.
Grrr >_<
Discussion Starter #8
never mind i did a search only thing is if there are multiple errors in teh ecu how do i tell the difference from the two sequences of lights blinking? the Check engine sigh is what will be blinking right? sorry to annoy im doing this for the first time.
thanks neil
Actually, the led on the ecu will be blinking. Each code is a series of slow/fast flashes (maybe the other way around) so you can tell the codes apart. Just get a pen and paper ready.
1 - 9 of 9 Posts
