1 - 11 of 11 Posts
The other day, i was having my brakes done and i figured id have a look c while the alty was up on the lift. I was surprised to find a hole about a 1/4 inch long and 1/16 in wide that had some fluid (smelled more like oil than tranny fluid) dripping off of it. It didn't look like it was supposed to be there so I patched it with metal epoxy. You can't tell that anything happened cause the epoxy worked great and the car doesn't run any diff so i was just wondering if anyone else has noticed this on the bottom of their trannys and if it's supposed to be there. Thanks, Matt
Ex 1st gen owner
its sposed to be there, same hole on bothe my SE and GLE. its a small drain if t-fuild gets in by your flywheel itll drain, I thought the same thing as you when my tranny went
1 - 11 of 11 Posts
