man there is a much easier way to do it rather than going out and buying something that you don't need. Just cut off the little thing that you would plug into your cigaratte lighter and strip the wires, pull them apart a little bit and remove your "audio" fuse there should be a fuse map located on the panel that you pull out. Just pull the fuse out place the positive (+) strip of the wire under the fuse and push it back into place, then just ground the negative(-) wire. Let me know if you have any questions.
