1 - 10 of 10 Posts
Does the HotShot header come with a downpipe, and if so, what is the diameter?
I'm thinking I'd want to replace the stock cat with something that's got either 2.5" or 2.25" inlet/outlet so that exhaust flow isn't constricted, but I don't know what length cat to get for a 2001.
FYI - I'd be mating this to my GReddy cat-back.
Discussion Starter #2
Also, the downpipe connects directly to the cat, right?
So if I install a header, cat, and cat-back exhaust there wouldn't be any other narrow stock 2" piping restricting my exhaust flow?
There is no substitute.
ERyNN29 said:
i think the header/downpipe eliminates the cat.
i never heard that before:confused: ... but if its true it will save me some dough with my hs 4-2-1 and greddy cat-back im gettin. But i think to get rid of the cat you need to put a test pipe in or something.
It eliminates the precat. not the actual cat.
Yes, the HotShot eliminates the pre-cat, but I'm wondering if it reaches all the way to the main cat?
My main question: would there be any other stock piping remaining after HS header + hi-flow cat + GReddy cat-back?
nope no other stock piping
I just put in my hotshot header and it does come with the down pipe and it doesnt eliminate the cat.
Discussion Starter #8
So... What size hi-flow cat should I get to go along with the new header and cat-back?
Specifically, what length cat should I use on a 2001 Altima?
I figure I could judge the proper inlet/outlet diameter by looking at the header downpipe and cat-back (either 2.5" or 2.25")
Discussion Starter #10
Thanks. Also, what LENGTH cat would I need to fit?
1 - 10 of 10 Posts
